Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit MEP Forum
File Menu hangs
1 REPLY 1
503 Views, 1 Reply
File Menu hangs
So I have done the usual stuff (clear Revit.ini recent file list and disable recents menu) but still Revit takes forever to open the File Menu. Any other ideas on this? I have crated some keyboard shortcuts to bypass it but for example when I try to export schedules this simply does not work....
1 REPLY 1
RobDraw
Recent files list is also stored in your user folder but I don't remember the full path.
Also, this has been fixed with updates to the program. Make sure you are fully updated. If you are running multiple version reinstalling might be in order. Make sure to install the versions in chronological order.
Rob
