File error form Architect
I'm trying to set of a new MEP file by referencing a file from and architect but I'm getting an error that says "the central model file 1 and file 2 cannot be found, perhaps due to a lost network connection" I recently downloaded these two files from a drop box account and when I open either file I'm missing floor plan layouts. how can I fix this?
talalaevd
Check your Manage Links in opened project. Check this columns2017-06-29_20-47-37.jpg
Дмитрий Талалаев
Эксперт BIM2B
Блог
Facebook | Twitter | LinkedIn
You need to open the architectural models, detach them from central, then re-save them as new central models.  The versions you have are still trying to find a central model on either the dropbox server or the architect's internal server.  Once you've detached and saved they'll path to the locations you have linked in your model.
