Family Thumbnail preview in properties within Revit
damon07
Message 1 of 8
damon07
Hi, does anyone know why after I edit or create a family, the preview of the device in the properties box is either blank or in a random position? Is there any way to set what each one looks like?
Replies (7)
Message 2 of 8
L.Maas
When you do a save as in the family editor, you have the options button.
Clicking that opens a new window
In there you can set the source for thumbnail preview
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
mauricio_mssf
In addition to the option given by @L.Maas ,
You can use a plug-in to configure more viewing options as if it were a template for any family member who can save with predetermined types of visualization.
https://apps.autodesk.com/RVT/en/Detail/Index?id=1718028284469690311&appLang=en&os=Win64
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 4 of 8
damon07
Thanks for the reply, I've tried this and it doesn't seem to update it after I load it into my project. Is this only meant to update the preview thumbnail of the file shown in the file explorer or is it meant to update the preview in the properties box within Revit also? The latter is what I'm looking to do, thanks.
Message 5 of 8
damon07
Thanks, unfortunately my company admin has blocked me from installing that file
Message 6 of 8
fabiosato
Adjust the position on a 3D view, right click with the mouse cursor over the viewcube and select Save View.
Fábio Sato
Message 7 of 8
raghurajan7C7HU
Community Visitor
Community Visitor
I Have the same issue still not solved all these steps done
Message 8 of 8
fabiosato
In save options, try to check Regenerate if view/sheet is not up-to-date.
Fábio Sato
