We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Family Parameters to specify standard Voltage Ranges
curtisridenour
Advisor Advisor
Message 1 of 1
curtisridenour
I was tasked with updating our Special Receptacle family to entirely Instance based parameters. I wanted to share what I learned and I wanted to thank @ToanDN for his previous solution that helped me along the way.
I started by incorporating a Lookup Table to find the NEMA Code information from the Voltage, Phase, and Amp-Rating (this can also be done in reverse).
size_lookup(LT, "NEMA_Code", "NONE", _Voltage_Nominal, Power Phase, _GROUNDED, _NEUTRAL, _TWIST_LOCK, AMP RATING)
Then I needed some nested NAnd statements to specify the Voltage range to match the project Voltage Definitions.
if(and(not(Voltage Nominal < 110 V), not(Voltage Nominal > 130 V)), 120 V, .....
https://forums.autodesk.com/t5/revit-architecture-forum/supported-conditional-operators-greater-or-e...
Lastly, I needed to have a comparison for the Apparent Power Calculated from the FLA and the Amp-Rating of the receptacle to find the lower of the two values unless the FLA was set to 0 amps.
Cheers and thanks to this community for a source of help along the way.
Replies (0)
