- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Need some revit geniuses over here. I am trying to make a set of families with "shut-off valve .dwg's" I got from a manufacturer's website. The goal is to make these all be in 1 or 2 drop down menus like they are when you get doors. Although each valve is gonna be unique (different sized connections, capped or with a handwheel, etc), I was hoping that I could load them into a project and have a drop down menu for the different options like it is when you load in an autodesk door family.
Been messing around with nested families, and it's not working. I've made a family called "cap" and one called "handwheel" and then loaded them both into a single family called "globe." Now when I load the "globe" family into a project, I don't get a drop down I just get them both sitting right beside each other, as one piece that moves together.
I think I need some text files or something? But as I'm pulling in the .dwg files, I'm unsure of what to put in the .txt as I'm unsure of all the minute differences between each drawing. All help would be appreciated!
Attached are a couple dwgs, a screenshot of what I mean by the drop down menu, my "globe" family, as well as the project I dropped it into.
