02:54 AM
Hi
On looking at Revit MEP supplied content (air terminals) the model will still flex when parameters are changed, but there seems to be no linking of the parameters to the model via labelled dimensions, how can this be. For example:
Looking at an extract grille or supply diffuser, under the Family Types dialogue->Dimension Parameters, modifying the width or height values changes the model, but the model seems to be missing any labelled dimensions? I am obviously missing something? I would like to start creating parametric families including blends and this is causing some confusion. Any advice would be appreciated. Thanks.
