*Face Based Family Hosted on Reference Plane relocating itself wildly on parameter change or family swap*
I have posted this issue before with no resolution but the error persists and so I assume it to be a bug somewhere within Revit.
Essentially I have a face based family I created (a sprinkler) assigned to reference planes in a project, with the benefit that these elements can be copied about slopes (reference planes) in a plan view and also display annotation symbols correctly without tagging.
While these appear to function correctly for a time, randomly some instances will start to malfunction and fly off their reference planes by large distances in both plan and elevation, breaking associated connections (see screen record).
This tends to occur when changing any parameter or swapping out the family with another almost identical one, meaning once they break you are stuck without solution but to delete the offending instances.
It does not occur with every instance but the extent of corruption appears to increase with time with no easy fix save manually replacing and connecting the elements (incredibly time consuming).
I have recreated these families from scratch after first encountering the issue to try and rule out family corruption but it persists and thus I assume it to be either an issue with the face based family or with Revit itself.
Has anyone else experienced this / found a fix and does anyone developer side know what could be causing this?
I have tried many possible solutions with the families to try and resolve and still retain the desired functionality. To not use face-based families is not a solution in my opinion as these should behave as designed and as stated they have unique benefits for the intended application.
It seems a fairly serious issue on the MEP side and causes severe issues for anyone like myself placing large quantities of hosted families in a project as the issue presents itself randomly with no definitive cause or solution.
I attach screengrab of the issue in action along with the family in use.
Thanks in advance.
