Fabrication Reports
Fabrication Reports
mattpick10
Fabrication Reports
mattpick10
Ok so I have finally got the metric fabrication parts to show in revit 2022 ( migration tool ) but when I go to print report the graphical views are all empty ( see image below ) its also the same issue with Revit 2021. Any ideas
derrick.venzor
I am with you on this. I have looked through all the forums, but no one has addressed this? I did get it to work in Autocad CAD-MEP Fabrication, but not in Revit.
mattpick10
Yes it’s a real pain. I read that the problem is with a Microsoft Windows update but I tried removing it but didn’t have any success. It just another Autodesk issue. Just wish they would spend it but more time on making sure there new release works before releasing. Not sure why we need a new version every year when there are so many issues in the previous issue.
derrick.venzor
I did get this to work. I needed to load Autocad Fabrication first, fix that, then load the Revit Fabrication. The years of the programs must match! See above attachments for check box to turn off, And as you stated, I had to uninstall updates from windows and lock them out. If you can get the pics to work in reports on the Autocad side, then the Revit will follow. Years must be the same. That was my error. I hope this helps.
