Revit MEP Forum
Fabrication parts scale
3 REPLIES 3
tracy_taylor
187 Views, 3 Replies
Is it possible to change the annotation scale of a fabrication part to be legible at smaller scales? For example, fabrication valves shown at 1/2" are too small to read on a plan view. Is it possible to add a symbol or something on top of the actual valve to make it legible? Similar to pipe accessory families, I can change to fine mode to print the actual valve, but can also use course/medium to show the valve symbol.
3 REPLIES 3
fabiosato
in reply to: tracy_taylor
If you are using tags, just edit the tags and change the label font size.
Fábio Sato
tracy_taylor
in reply to: fabiosato
No it's not a tag. I am asking about the graphical display of a fabrication part in Revit. They are the real element from the fabrication database. But can we add annotation to the fabrication part to get it to show legibly on a 1/2" plan view?
fabiosato
Ok, now your problem is clear for me, I don´t use fabrication parts, but AFAIK they have only the geometric representation, no symbol in them.
Fábio Sato
Forma Design Contest
Technology Administrators
