Fabrication Intent Modeling (There are so many padlocks)
Yucel_Kaya
Yucel_Kaya
Dear participants, I need your advise about workflow for Fabrication Intent Modeling.
The subject is modular framing.
The frame can be a family. In this case:
Just I do not want to see padlock icons while modifiying the set. I put the constraints in order to make model flexible and constarained. Horizontal bar and vertical rods are line-based families. All other familes are work plane-based, but not associated any work plane. They have been constrained either allignment or dimensionally.
It is apreciated to advice other workflow with same functionality.
I am dreaming about two things:
First, Autodesk will add hide/reveal padlocks button.
Second, Autodesk will develop parametric assembly.
RobDraw
You posted the same question a few days ago. You should just reply to your other post if you want to attract more attention to it.
Rob
Yucel_Kaya
I thought that I may get advise from MEP forum.
RobDraw
Did you not believe me?
Have you been to the IDEAS forum?
Rob
Yucel_Kaya
Hi Rob,
I believe you.
I did not post to IDEAS forum. I thought that Autodesk has a lot of issues to overcome/develop. They advise me to use 3rd party applications for my intent.
