Exporting to cad by System classification.
Lucas_Giovanola
Lucas_Giovanola
Hi everybody.
I´m trying to make a template which content the layer standar namig for the project.
And It works correctly. I use a Layer modifier to put my entities in their correct leyer by System, As the Picture show.
I made that because I need the ducts separated by System.
However when I try to export sheets witch sections or 3d, the blocks that revit create to export are in layer 0.
I read that moddifiers don´t change identities inside block, may it is the reason?¿ And if it is. how I could separate ducts by system when I export a secction?
I Will appreciate any contribution.
Thanks and regards.
Lucas - from Madrid
Replies (0)
