Exporting Electrical Panel Schedules to Excel
williams_cory_a
Message 1 of 22
williams_cory_a
I am trying to export an electrical panel schedule to an excel sheet but even when the view is active the Big R>Exports>Reports> Schedule is greyed out. Is there a better way to export an Electrical Panel schedule to excel?
Replies (21)
Message 2 of 22
GungorOzay
You can use the Dynamo. Just download Dynamo final version. And in dynamo you have to add Packages ; Data-Shapes, bimorphNodes .
Than, just download attach script and run in your project.
Güngör ÖZAY
MEP BIM MANAGER
Youtube | LinkedIn
Message 3 of 22
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @williams_cory_a,
I was able to reproduce this issue - I am not sure, why this option is not available for electrical panel schedules, so I went on and started an investigation to let the product team review the current product design in this regards.
The status of the investigation is documented here:
http://knowledge.autodesk.com/article/Revit-Exporting-Electrical-Panel-Schedules-to-Excel
This link will be active in a couple of hours and will be updated with news as soon as available.
In the meantime you might want to give this 3rd-party tool a chance:
Panel Schedule Exporter
Also: I found a similar wish for enhancement reported on the Revit Ideas page here:
Allow Export and Import of Panel Schedule Templates and other model settings
Please, feel free to vote for that enhancement request or to add further ideas.
I hope, you´ll find this information and the tool helpful.
In order to point other users to this information I will go ahead and mark this post as a solution - but I want to encourage you to continue the discussion or give feedback about the tool above in this thread.
Best regards,
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
Message 4 of 22
Hello, I am not very good with using Dinamo. Could you please be more specific about the procedure? Should I open the desired panel schedule first and then run this script thourh Dynamo Player or select the panel schedule from the Project Browser and then run the script? Either way I get empty Excel to open (and error message). What am I doing wrong?
Message 5 of 22
GungorOzay
Can you send your dynamo screenshot ? And be sure you have already dynamo package ; Data-Shapes, bimorphNodes
Güngör ÖZAY
MEP BIM MANAGER
Youtube | LinkedIn
Message 6 of 22
This is what I get when I open the panel schedule and run the script
through Dynamo. I am using Dynamo 2.0.1.5055 and Revit 2017. As a result,
Excel would open and it would be empty.
You can see I have add-ons already loaded.
[image: image.png]
Message 7 of 22
GungorOzay
i thing image not attached. Can you try again please ?
Güngör ÖZAY
MEP BIM MANAGER
Youtube | LinkedIn
Message 8 of 22
Here is the snapshot of my screen.
Message 9 of 22
GungorOzay
Sorry, but i still couldn't see your screenshot.  I thing you still didn't attached to here.
Güngör ÖZAY
MEP BIM MANAGER
Youtube | LinkedIn
Message 10 of 22
The reply on Autodesk portal takes me to Gmail and I attached the file but
it did not get through.
Do you have an alternate email that I can use?
Vlade
Message 11 of 22
Ashkan_Kermanian
If you have Bluebeam, you can export your panel schedule through File> Export>Excel
Message 12 of 22
Capture.PNGhow to solve this?
Message 13 of 22
Interesting. I wasn't aware of this feature. I need to give it a try.
Message 14 of 22
fabiosato
You have to download the Dynamo packages, please check in the Dynamo forums.
Fábio Sato
Message 15 of 22
benjamin_miranda
@Gungor.Ozay, tried the dyn file above but exporting i get a blank excel sheet (see short clip below). Appreciate if you can shed a light on this.
Message 16 of 22
benjamin_miranda
Never mind I've sorted it by replacing "Element.Name" to "String from Object".
Message 17 of 22
GungorOzay
Uninstall your Data-Shape package. And download last Data-Shape Package. It will work.
Güngör ÖZAY
MEP BIM MANAGER
Youtube | LinkedIn
Message 18 of 22
benjamin_miranda
I just actually downloaded/installed the datashape package before this test.
Message 19 of 22
I found this trick.
1. place your panel schedule on sheet.
2.Export the sheet into PDF.
3.Open PDF in xchange Editor.
4.Save as .xls from file menu in xchange editor.
Done
Attached file is my output, which is as same as panel schedule in Revit.
Message 20 of 22
Michael.Meyers615
2.5 years later, updated those nodes, and had to update the GetData to the new version but worked like champ! thank you sir!
