Export combined parameters to nwc
kristoffer.flygareMX5FB
I have a somewhat complex naming convention in my model files.
Where the last column, "ObjektID" is a made by combining the other ones. Every part of the objekt identifier or "ObjektID" is separated in its own columns, which I like. But I want to export this combined parameter as a "real" parameter in my NWC file. Is there some way to do this?
Thanks!
keithrossuperior
In the Navisworks Options Editor do you have "Convert element Parameters" on "All"? and Convert Element Properties Checked?
Thanks for your reply Keith,
Yep they are both checked but still the ObjectID isn't exported
I've checked multiple categories but no ObjectID. All the shared parameters export as expected.
Okay, so I solved this by using Dynamo, seems to work like a charm!
