Encountered a sharing violation while accessing - Revit issue
shey.ana.makay
Message 1 of 39
shey.ana.makay
9times out of 10 when I go to sync with the central I get an error saying this:
It is followed by a message saying "File not saved." This occasionally happens when I just want to save but definetly not as often as trying to sync. I've deleted all my files from my temp and made sure my firewall is not blocking anything revit related. For this project the central file is on the cloud in A360 but I find the same thing happens even with a file saved on our network. I've had my windows profile re-installed and not sure what else to try? No one else in the office seems to have this issue. Please help!!
Replies (38)
Message 21 of 39
Здравствуйте! Я студентка первого курса строительного института. У меня возникла ошибка при сохранении файла в программе Revit 2018. Я использую Revit 2018 два месяца и не разу не сталкивалась с такой проблемой.  Моя модель ноутбука Acer Swift 3. Не могли бы вы подсказать, может ли быть связана эта проблема с возможностями моего ноутбука?
Жду ответа как можно скорее.
lady.zhurawleowa2000@yandex.ru
Message 22 of 39
thank you!
Message 23 of 39
I have recently encountered this one and the issue was isolated to our Micro Trend antivirus. Follow these steps on how to do the anti-virus exclusion process.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Message 24 of 39
it works perfectly well. this is about the best solution so far... thanks for sahring
Message 25 of 39
I had this problem, as well (circa 6/1/2019).  I have Bitdefender and Microsoft Defender running, plus some adblockers.  I turned them all off to no avail.  HOWEVER, a recent update by REASON CORE SECURITY gave me access violations on both Revit and Adobe Acrobat Pro.  I uninstalled REASON CORE SECURITY and the problem was solved.  To be frank, I don't even know how i ended up with that program on my computer - I thought it bundled with Bitdefender or something.  So anyway, check ALL your anti-virus/firewall/security programs - those you know you have and those you don't.  Also check your "Recent Updates" under "Programs and Features" in "Control Panel."  This will show you all the unavoidable updates that may be wreaking havoc with your computer.
Message 26 of 39
tmont10465
Community Visitor
Community Visitor
Thanks for the heads up about the anti-virus software.  I think during a Microsoft update an obscure anti-virus program was added to my computer.  After this update things went wrong with Revit.  I uninstalled the spyware and Revit works good again.
Message 27 of 39
Mine was a segurazo antivirus blocking the revit file from saving.
Message 28 of 39
tmont10465
Community Visitor
Community Visitor
My sharing violation was created when Microsoft provided an upgrade and downloaded an anti-virus program on my computer. I deleted to program and revit worked fine after that.
Message 29 of 39
I have the same problem. In my case the error happened because there is an antivirus named SIGURAZO which installed automatically when I surfed internet.
The SIGURAZO was blocked my Autodesk License so make the Revit doesn't want to sync also save the file.
To resolved the problem I just remove the SIGURAZO from my PC.
But if you don't wanna remove the antivirus you may check the antivirus setting and then let the revit running on your pc normally.
Message 30 of 39
i'm from Vietnamese, i seach to web autod desk when i can not save file revit because '' Emcountered a sharing violation while accessing ''.after I unistalling ati-virut softw .My revit have active good.Thank all you.
Message 31 of 39
tmont10465
Community Visitor
Community Visitor
DELETE THE LATEST ANTI-VIRUS SOFTWARE THAT WAS JUST DOWNLOADED TO YOUR COMPUTER FROM MICROSOFT AND THE ERROR MESSAGES WILL GO AWAY.
Message 32 of 39
very Helpful
Message 33 of 39
If After uninstalling Anti-virus app, my PC not safety.
This means it's very DANGEROUS for me, I think that all I know is that the Ransomware Virus can get rid of all the data.
This is not a solution.
Message 34 of 39
I found it,
when i got this error, i cancelled it then synchronized again by select the option of compact central model
hope that helps.
Omar Diaa
BIM Coordinator
Message 35 of 39
  • I have tried many things over a period of time... But how to figure out that what might be causing this issue???
Message 36 of 39
kschicker
Is AutoDesk going to resolve this issue??
In my opinion, the "solution" of disabling your AntiVirus is not a real solution, only a temporary workaround.  We all cant permanently disable our AntiVirus.  Our IT Dept isnt going to let this fly on a permanent basis, nor should they.  That isnt sustainable.
I believe Autodesk should work to resolve this, so everyone doesnt have to permanently put their computers at risk to use Revit.
Message 37 of 39
iainsavage
Can you not just apply exception rules for Revit in your AV software rather than completely disabling it?
There’s a troubleshooting page which says:
  1. Verify that antivirus, firewall, or WAN software is not blocking or placing locks on the following file types. If needed, exclude or add an exception to the file types listed below:
    •  DAT
    •  RVT
    •  RWS
    •  SLOG
    Revit needs to modify and create these files when synchronizing with central for backups and the worksharing log.  If any of these files are inaccessible the error message will occur.  See: How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
Message 38 of 39
julian.fikri
thanks for the information. this is really helpful.
i had the same problem. then i just uninstall the antivirus software and the problem solved.
Message 39 of 39
JAR3K
I had the same problem with Bitdefender Total Security
Resolved the issue after I adding these to my rules:
C:\Program Files\Autodesk\Desktop Connector\cdxsenddmp.exe
C:\Program Files\Autodesk\Desktop Connector\senddmp.exe
