elements grayed out
elements grayed out
revitworkbench
Message 1 of 11
elements grayed out
revitworkbench
Hello, I seem to have a problem with my duct fittings coming in greyed out. I checked the object styles and the VG menu and they are both the same as the ductwork yet appear to be greyed out (see below). I figure this has to be a Discipline issue, but I have it set to "Mechanical" Discipline, so shouldnt the ducts and the fittings be showing up the same? Thanks!
Replies (10)
Message 2 of 11
Diego.Faria
Same happens if you set discipline to Coordination?
Have you expanded the Duct Fittings category in VG and checked if any of the subitens has something set to them?
Any filters maybe?
Diego Faria
LinkedIn
Message 3 of 11
jsgalve
Not halftone on Visibility Graphics?
Or maybe try Object styles.
Worksets perhaps?
Message 4 of 11
ennujozlagam
@revitworkbench hello, have you tried to check the "phasing". thanks
Message 5 of 11
revitworkbench
No, it appears to be a view range issue. When I raise the cut plane it goes away. But I cant have the cut plane raised here. It also doesn't explain why duct fittings are appearing differently than ducts. 😕
Message 6 of 11
revitworkbench
@Diego.Faria yes the same thing happens in the coordination phase. and no, there are not any filters.
@jsgalve no its not a VG or object styles issue. I already checked those. Please advise. Thanks. See belowCapture.PNGCaptur3e.PNGCaptur1e.PNGCapture2.PNG
Message 7 of 11
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @revitworkbench,
Can you try setting the underlay to none in this view?
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 8 of 11
jsgalve
Hi again!
https://forums.autodesk.com/t5/revit-mep-forum/pipe-amp-duct-bends-fittings-all-grey/td-p/3298799
Try to set the underlay to none just like this guy did.
Message 9 of 11
Simple, short reply.  I love it
and most import it was the correct answer for me 🙂
@andrea.kikuchi wrote:
Hi @revitworkbench,
Message 10 of 11
MiWolff
Thanks for this solution. Is there any explanation why pipes behave differently from everything else when an underlay is in place?
Message 11 of 11
paraoigor
Community Visitor
Community Visitor
I've created an account just to thank you.
Thank you.
