Revit MEP Forum
Electrical plan
7 REPLIES 7
Message 1 of 8
sabamail65
289 Views, 7 Replies
Electrical plan
Hi.I have drawn the electrical plan, but unfortunately all the lights and sockets have appeared in other maps, such as plans and sections. What can I do to be seen only in the electricity plan?
7 REPLIES 7
Message 2 of 8
robert.klempau
in reply to: sabamail65
Hello @sabamail65,
I would suggest you to look into this Autodesk article about creating and assigning View templates to your Views.
With View templates, you can create your company standards for all the View Types you are using.
Assign them to your project Views so you can manage the visibility in one place.
you can manage the:
  • Model categories
  • Annotation categories
  • CAD imports
  • Filters
  • Linked files
  • Design options
  • Worksets
Please see the article below:
About View Templates
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 3 of 8
RobDraw
They need to be turned off in the V/G Overrides by categories.
Rob
Message 4 of 8
sabamail65
in reply to: RobDraw
Sorry did not notice. Can you show it visually?
Message 5 of 8
RobDraw
This is basic stuff every Revit user needs to know. Put it into your favorite search engine and you will find everything you need to know. It's been covered many times, many ways.
Rob
Message 6 of 8
robert.klempau
Hello @sabamail65,
Go to 'Visual/Graphics Overrides' in your properties or press VV on your keyboard.
when your don setting the Visual Graphics Right, you can create a View template of this View and use it in other similar Views.
Just right-click on your View and select 'Create View Template from View'
Please see my first post to your question and the link to the Autodesk Knowledgebase.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 7 of 8
sabamail65
in reply to: robert.klempau
Sorry . I want to draw a simple electrical drawing that does not appear in other drawings when I put the lights and sockets in it. Unfortunately, everything I did to your method did not work. Show the possibility in the form of a film?
Message 8 of 8
J.Wehmer
@robert.klempau showed you step by step how to do it. If you cannot follow 2 images a video won't fix the issue for you.
Sounds like a Layer-8 error you need to get fixed. These forums cannot help you with that.
-Please click accept as solution if this answers your question!
Forma Design Contest
