I am hoping that there is a way to 'batch' Update Names for circuits. So instead of having to go to the panel schedule, select the circuit, and run the command, there would be a command to just do all circuit, or circuits of designated panels. I am hoping that I am missing something easy, but I have not found anything anywhere. Not even another post asking about it. Running 2017.
Solved by scott_dakin2. Go to Solution.
Circuit naming in Revit follows this pattern - [Load Classification] [Space Name-Number].
If you want them to be changed to anything else you have to do it manually.
We've only just started moving into 2017, so I haven't had occasion to use the "Update Names" command, but I doubt I ever would because for the most part I don't want to use the default naming convention for ~50% of the circuits in a given project.
Its only available for each panel schedule on its own, there is no global command to do this.
I use this automatic feature for pretty much every circuit.
