Editing Tags
Editing Tags
coleLHPZ3
Editing Tags
coleLHPZ3
Hello, I am wondering if it is possible to change out the comma in a 3 pole circuit and replace them with a slash?
rudi.roux
Hi @coleLHPZ3
Hope you are well! Smiley Happy Could you possibly assist with a screenshot of the comma which you're trying to change? So basically a screenshot of your current tag.
Thank you!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
coleLHPZ3
Here is the tag. That is currently a 3 pole j-box that takes up circuits 2,4,6. Would it be possible to exchange the commas with slashes.
kadmonkee
you can change that in your Tag family
edit family select the label you want to edit and add the suffix - or prefix depending on where you want the Hyphen to display
this example will result in Panel-1 your example will be L1A-2-4-6 with the suffix for each circuit being a Hyphen not a comma
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
"this example will result in Panel-1 your example will be L1A-2-4-6 with the suffix for each circuit being a Hyphen not a comma"
No it won't.  It'll put a dash after the panel name, but the circuit will still be named "2,4,6".  So far as I know, there's no way to change that in any Electrical Setting.  I want it to read 2(4,6), personally.  But I've never seen anyone able to alter the default multi-pole circuit numbering system.
kadmonkee
my mistake I left out a piece of info that I thought might fix the problem
I tried to change the display here at the Electrical Settings General, Circuit Sequence from (1,2, to 1-2-)
Revit does not like that.
this is what drives the result
this may be an Revit API solution
thank you
We are having the same issue.  Did anybody figured out how to use slashes instead of commas on a 3 pole circuit?
