Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
DWG export problem
5 REPLIES 5
amin_energyx
326 Views, 5 Replies
DWG export problem
amin_energyx
Hello everyone,
Every time I export something from Revit, I don't know why the ground becomes white and it hides the duct and pipe work. It's very urgent. Has anyone seen something like this before?
DWG export problem
Hello everyone,
5 REPLIES 5
hmunsell
in reply to: amin_energyx
hmunsell
  • do you have a pattern applied to the floor?
  • what export settings are you using?
Howard Munsell
Howard Munsell
amin_energyx
in reply to: hmunsell
amin_energyx
It's better, but there's still a red background. Could it be due to the architectural link?
(floor is "sol " in french )
that's the export setting that i used when i printed the last file
curtisridenour
Try this setting.
Try this setting.
hmunsell
hmunsell
Would you be able to upload the model for us to look at?
  • if the model is too big, make a copy and delete unneeded content to display the issue.
Howard Munsell
Howard Munsell
amin_energyx
