Ducts drawing
Ducts drawing
Ducts drawing
Hello. I have a problem in revit 2019. I draw duct system and I have an issue.
When I draw duct, the duct is drawn by line and I also see the line in level 3  (top floor view). Only In the 3D view the duct is drawn normally. But when I tur on active workplane viewer the duct is normally shown on 2d drawing I also can draw duct normally in active workplane view. How could I fixxed that?
rudi.roux
Hi @Anonymous
Hope you are well. You need to adjust your view display detail level from coarse to medium or fine which will display your ducting as double lines opposed to single lines.
Also have a look at this Autodesk Knowledge Network (AKN) post which explains the detail level differences.
Post Link
I hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
