Duct Systems AND Graphic Overrides
lee.imbimbo86EM4
lee.imbimbo86EM4
I may be missing something, but is there is a way to control the graphical display for duct systems on a view by view basis.  All I can seem to find are overrides that govern global appearance, but what I'm looking for is to make it look a specific way in a view that I'm working in.
Right now I've found that I can scroll down in the Family Tree and apply a Graphic Override to a Duct System, but that is a global override.  Alternatively if I don't use that override it would seem that I can apply a Filter for a view specific element.  Although it would seem that I can't apply a filter that overrides the override in the Family Tree.
But when I got to the view that I'm trying to work in and run an override through the Visibility/Graphics, there is no Duct Systems Category for which to manage that Override.
Any ideas?
HVAC-Novice
I color pipes and ducts based on what type they are based on this standard. Filters include fittings, accessories etc. Then I created filters for each type. in each view template I assign the standard colors. You have to manually assign colors for 3D, floor, section templates.
Depending on what and how you want to color, you need to adjust what I do to use other parameters etc.
Hope this helps
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
iainsavage
If you're using system graphic overrides you can still override the graphics in a view by using a filter.
lee.imbimbo86EM4
I'll give it a try and see if I can't make it work again. Thank you for the response. I'll respond later if it works
iainsavage
With system graphics override:
Same plus view filter:
lee.imbimbo86EM4
Took some messing around to get it to work right, but finally got it working well. Thank you @HVAC-Novice
