Revit MEP Forum
Duct graphics on plans
6 REPLIES 6
909 Views, 6 Replies
Im new to the mechanica side of Revit and Im being tasked with standardizing the graphic symbols.
My engineers want our graphice to display in two different ways to differentiate between a duct going up versus a duct going down (below).
I have attached an image of what they want. Any ideas on how to achieve this? I cant figure out how to edit the family as it is a system family. Any help is appreciated.
6 REPLIES 6
MichaelSpahn
MichaelSpahn
check out this post https://forums.autodesk.com/t5/revit-mep-forum/vertical-pipe-size-of-circle-symbol-in-coarse-or-medi...
from @rklembau
Stay hungry, stay foolish!
Viele Grüße,
Michael Spahn
TGA Planer/Konstrukteur
Firmenwebsite | LinkedIn
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
from @rklembau
Viele Grüße,
Michael Spahn
I have done drawings for years and when you are creating plan drawings and the pipe/duct is cut in the view I show the symbol on the right. If they are wanting to have an option you can create an annotation family and have it built in with the option of showing either with a visibility option. Just my thoughts.
RobDraw
RobDraw
You cannot edit the families. You can only assign one symbol to represent both the rise and the drop. You need to pick from the options available within the program. This is an area that Revit has struggled with over the years. Be prepared to override the graphics (line weights and patterns) for certain situations.
Rob
Rob
in reply to: RobDraw
its from piping system properties u can edit it it is easy...
RobDraw
RobDraw
The only thing you can do from there is choose which one to use. The question is about editing the symbol and having an option to assign separate symbol to represent for rise and drop.
Rob
Rob
