Duct fitting offset
Duct fitting offset
gregor.gojkosek
Duct fitting offset
gregor.gojkosek
Dear Sir or Madam,
I am having problems connecting two ducts that are aligned on one side, noncentric and have different Width dimensions.
In attachment I am sending a .rvt file. I would kindly like to ask for a screencast of solution on how to connect those four duct pairs.
I am looking forward to your solutions.
Many thanks,
Gregor
  • Duct
stevenson953
Have you tried using Transition from MEP Fabrication parts?
I'm no expert and I joined them up easy enough.  See attached.
gregor.gojkosek
Many thanks for your reply. I have tried that and have managed to complete it successfully on the first two pairs of ducts. But I cannot do it on the one that is: non concentric, aligned (on one side), different in dimensions.
Kind regards
Gregor
stevenson953
Can you please attach just the two you are having problems with please.
fabiosato
If you change the transition used in the routing it will work better, the one in the duct seems to be always created as concentric.
Another point, when you want two segments to be aligned by an edge, select both and specify the justification you need.
Fábio Sato
