Revit MEP Forum
duct accessory Size - how to show size only once
2 REPLIES 2
HVAC-Novice
201 Views, 2 Replies
I have dampers and other duct accessories. And the tag should show the size. but since the accessories have 2 sizes (air entering, air leaving) the oob "size" parameter in a tag shows me the size twice. For most (if not all) dampers and other devices the size will be the same in and out. At least I can't think of a fire damper, airflow station or anything else that would be a transition (e.g. entering size different from leaving size)
How can I make it to only show the size once? See below, i only want to show "24x16" instead of "24x16 - 24x16".
Best idea so far is to create shared parameters that use width and Height of the duct and create labels from those. but I wonder if there is a better way? In the tag I can't format the "size" parameter.
I'm having the same problem with Pipe accessories and there ended up using a separate shared parameter.
Revit version: R2024.3
2 REPLIES 2
fabiosato
in reply to: HVAC-Novice
The Size parameter normal behavior is to show all connector's sizes.
To avoid it, the only solution I use is a shared parameter.
Fábio Sato
HVAC-Novice
in reply to: fabiosato
Thanks for the response. That is what I feared.
Forma Design Contest
