Drawing vertical conduits when parallel become angled??
victorwongiam
victorwongiam
I am trying to draw a riser by first doing an elevation view and conduits straight through the slab.
Then I parallel them accordingly.
But when I go to PLAN view they conduits are at an angle. Either I have been staring at the screen too long or something is wrong? Please HELP!
rudi.roux
Hi @victorwongiam
Hope you are well! Smiley Happy
Is it only Vertical Conduits, through the slab without any bends? If so, you can also make use of the ARRAY TOOL and create a linear array.
Also, if you have bends and you need to use the parallel conduits tool, I would select the runs in the elevation/section, then click on my plan view window to activate it, then use the parallel conduits tool from there.
Let me know if you still receive the same problem. Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
victorwongiam
Thank you Rudi for your kind message.
They are straight risers and it worked perfectly! Although in the future if I want to move a row closer or farther, I was playing with the ungroup and shifting the row over in plan view?
