Domestic Hot Water & Hot Water Return Coupling
- Mute
- Permalink
- Report
I am having trouble keeping the System Type's I have defined for domestic hot water and domestic hot water return piping when I try to connect the two together. If you were to try to "tee" the systems together, Revit defaults to changing the system type to one of the two, thus I lose one of the systems. I have managed to create a generic coupling so I can connect the two, however, the fitting will only maintain the "coupling plan symbol" if I keep the same pipe size on both sides. In many situations, the domestic hot water return will be 1/2" and the domestic hot water may be 1". When I change the pipe sizes, Revit changes the pipe accessory from my coupling to a reducer with different symbols.
Does anyone have any recommendations or solutions they implement to solve these issues?
The photo below I started at the bottom with 3/4" and here is what is happening when I change pipe sizes.
