Do you use an intermediate .rvt when setting up MEP projects?
mshamalla
mshamalla
Does anyone else use a canned  .rvt as a way to filter incoming models from Architects when you setup a new .rvt MEP project and all the views, etc. for your company? Another way to put this; instead of trying to force the architecture model to provide company standard views with all the right settings when starting up a project, you filter the incoming model through another model before it gets used as the background in a full blown MEP project. That filter .rvt already has all the views set up (or at least the ability to easily setup standard scaled views). This prevents having to go back and reapply all the view settings to an Architects model if they resend it a bunch of times and you don't want to have to go back and totally reapply all the views, and settings each time - just run it through the canned filter .rvt..
I'm trying to get a feel for workflows; project volume is big here, setting up and maintaining standard views is a big deal.
RobDraw
Nope.
The view settings for links are preset in my template. I use dummy links but they are not used to "filter" the incoming models. In fact, they don't get edited much, if, at all. I like to strip them down to clean them up but it's not necessary.
Rob
Setting up and maintaining standard views in your project's view templates.  When you get new background models, the content changes but the visibility graphics do not because you control them.
s.borello
Nope, I basically do what @RobDraw does.
