I have created a one pole electrical panel which I edited it and add an extra 3 pole connector with 220 voltage and
I have created a three phase distribution system in the electrical settings. But when I click on an electrical panel that i created in my plan, and try to assign a distribution system from the drop down list, the only option is the single phase distribution system. The distribution system I created in the settings has not appeared in the drop down list. What should I do?
No, I also changed the voltage range to 380 V but still it does not show up in drop down list.
How could I have a panelboard with two input connectors that one includes single phase voltage and the other three phase voltage?
Hello @Anonymous,
Your Single Phase Panel has two connectors with different Pole numbers.
That's why you can't select the Distribution System.
Change the poles to 1 or remove the connector with pole number 3.
Load it back into your project and then you can select the distribution system.
