Revit MEP Forum
distribution system does not appear in drop down list in revit 2022
6 REPLIES 6
660 Views, 6 Replies
I have created a one pole electrical panel which I edited it and add an extra 3 pole connector with 220 voltage and
I have created a three phase distribution system in the electrical settings. But when I click on an electrical panel that i created in my plan, and try to assign a distribution system from the drop down list, the only option is the single phase distribution system. The distribution system I created in the settings has not appeared in the drop down list. What should I do?
Labels (1)
6 REPLIES 6
Aren't panel connector voltages and distribution system voltages supposed to match?  Yours are not.
in reply to: ToanDN
i have changed
it but it does not work yet!
Is 380v within the 360v range defined in project?
in reply to: ToanDN
No, I also changed the voltage range to 380 V but still it does not show up in drop down list.
How could I have a panelboard with two input connectors that one includes single phase voltage and the other three phase voltage?
Show the voltage range table please.
robert.klempau
Hello @Anonymous,
Your Single Phase Panel has two connectors with different Pole numbers.
That's why you can't select the Distribution System.
Change the poles to 1 or remove the connector with pole number 3.
Load it back into your project and then you can select the distribution system.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Forma Design Contest
