Creating Parametric Array in Revit Project
Revit ProjectRevit ProjectDear all,
How to assign parameter to the array created in Revit Project. As i know, i am able to assign parameter to the array that i have created in Revit Family, there is one interface at the top of the view tab where i can achieve that, but not in Revit Project. Kindly help advise how to do this. Sample model is attached for your perusal.
Thanks.
L.Maas
You can not add a parameter to an array in the project.
As you already indicated if you need the array to be parametrized you should incorporate that in the family itself.
Louis
Please mention Revit version, especially when uploading Revit files.
