Creating a Revit duct transition
brianwclayton1969
brianwclayton1969
Good morning Revit MEP users, I'm in need of assistance on creating a Duct transition part. I have tied to create it with connectors at 3 ends and I cannot figure out what I have been doing wrong. I have created these before and some reason nothing I have done is working. I need the part to change sizes on each end when its connected to a different duct size without adding additional transitions or parts. I have added a picture and an inventor/.rfa part. The Inventor/Revit family doesn't change size at the connector part. I tried to ad the revit family that was created in inventor but it would accept it.
Any assistance would be appreciated
Thanks Brian
CADmonkey_UK_Building_Services
Can you post the RFA?
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
It's an inventor part (.ipt) converted to a Revit family (.rfa), but the Autodesk link won't accept it. Every time I link it the post deletes the link. Is there another way to for me to send it or link it?
Thanks Brian
I'm sure I've seen RFAs posted before. Maybe it's got something to do with your side.
Load the part into a fresh project and upload that?
apjones
Brian, I sent you an email.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
