Create a long drainage GRILL
I want to create a long drainage grill as shown in the attachment. Please help me by giving a method. I use Revit 2014 . Thank you
kadmonkee
if you search online you can find what you want
check this link
https://bimobject.com/en-us/product?freetext=trench%20drain
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
ben
I don't know if your using the Zurn brand or not, but here is a link to the Zurn trench drain for revit.
https://bimobject.com/en-us/zurnindustries/product/zurn-z886
If you just go to the Zurn website>Products (any product, doesn't have to be trench drain)>pick your product>click the recourses button
Right under the recourses button, the 1st section is specs & install, 2nd section is links to dwg's and rfa's
Revit lives in the land of perfect and doesn't understand what construction is.
Actually i want to create a family of grill, because i want to adjust the length by dragging and dropping, like walls
so is there any method like wall sweeping ,reveling or using a profile .......?
ben
That I couldn't tell ya. I've never used the trench drain in revit before, but it might let you select the length that you want.
