Could not open revit file completely ?
I try to open a revit file, but it gives me this message:
Revit could not find or read 1 references files. What do you want to do?
Unresolved CAD or DWF markup files will be displayed as they were when the project was last saved.
When I open it, I only show part of the revit file?
Is that there is a linked file nested inside ths one?
What is the problem?
Thanks!
CoreyDaun
Go to Manage tab » Manage Links to find out what links are missing. If the model came from another company, then you will not be able to reference the Lined CAD files on their local server, hence the error. You would have to obtain a copy of the CAD/DWF files and then click "Reload From..." to redefine the path to the linked files. Alternatively, if a link is of no use to you, you can select it and click "Remove" to eliminate this error.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Thank you CADastrophe!
I go to Manage links tab, click Revit item, it show Linked files : Arch_link.rvt
Status: Not Found.
Reference Type: Overlay.
Positions not saved:
In fact I can find the Arch_link.rvt file, it is in different folder.
Thank you!
mukherjeerohan46
Community Visitor
Community Visitor
i have a question can we compress the file all together when we open the file it will show the all?
iainsavage
You can bind links into the host file.
mukherjeerohan46
Community Visitor
Community Visitor
So here is my situation i need to send a mep project to my sir now when i send the mep file the architect overlay not showing so i need to go in the manage link option the load from the architect file then it will appear...so now i need to send him 2 file  ...is there any way to do it in one rvt file i m new in this field so i dont know that much
