Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello all.
I've this filter settings in one floor plan and I need to copy it to another section.
This is the section as you can see there isnt any filter There is a way to copy from another or I just have to set one by one?:
Solved by Baptiste-Vidal. Go to Solution.
Solved by iainsavage. Go to Solution.
create a new view template and apply all views you want to apply
Just to clarify @ennujozlagam suggestion, you can use "create template from view" from the view which has the filters.
This will create a new template. Then in that template UNTICK every category except filters.
Then apply that template to your other view - this will retain all settings in that view but will add the filters.
Then you can repeat "create template from view" using that second view and now you have a template that can be used on views similar to that one
You can also use the EF-Tools from Erik Fritz (you can find it inside PyRevit extension.
Very usefool tool to copy filter and override state into other views with or without using view templates
