Hi
Just want to clarify with anyone here about:
1. whether the monthly cooling load graph produced by the energy analysis is done using the Radiant Time Series calculation method?
2. Can the monthly cooling load be refined into an hourly one? (Tried changing report type to "detailed", didn't help)
Thank you!
Solved by Mahmoud.Ziedan. Go to Solution.
Revit uses RTS method for Load Calculation.
Unfortunately changing the report type doesn't affect the calculation, it just controls the quantity of information that is shown in the report.
Does results of calculations reliable? Have you compared it to any other commercial calculation program?
I did not say that the results are reliable. I only said that I did use it.
