Constructions.xml editing?
Newbe!!! Hi there this is my first ever post on this website.
I Need to edit the Constructions.xml  file to change some descriptions and U values.
The only thing is I Am not familiar with .XML Coding and Syntax is there anyone here that can give me a few tips like how the file has been structured  and or direct me to a website or a .XML training manual Please?
Hi
Firstly - do you need to really amend the constructions in Revit? Are you going to use Revit for the energy analysis or are you going to export the geometry to gbXML and analyse in an external package? Many people export to external packages as we know the external packages are more reliable. If so then the constructions are exported but not always imported by the external packages. Therefore the constructions within the templates of the external analysis package should be set up for use better.
If you still need to change the constructions - check out the following course from Stanford University
http://http://www.db-class.org/course/auth/welcome. Its a great course and the bit on XML will definitely help you understand XML. For editing, I would recommend Notepad++ or XML Notepad (in that order as Notedpad++ is simpler to use) and both are free
hi..anyone knows where this constructions.xml file present in REVIT MEP 2013 installed setup on  pc ?
i wont able to find it in my 2013 revit setup.
i want to edit this file to assign U values & material properties.
