Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit MEP Forum
Connectors
3 REPLIES 3
rraghavendraTT3JQ
208 Views, 3 Replies
Connectors
Is there any way to change the connectors of several pipes together in the revit model? For some reason the connectors are changed to none and I have been selecting one pipe at a time and changing connectors for each of them
3 REPLIES 3
I've no idea what you mean by this. Do you mean the system is undefined?
For some reason the connectors are changed to none and I have a bunch of pipes for which I need to select the connector connectors from the scroll down. When i select multiple pipes i dont get the " edit Part" option to change the connectors.
You mean Fabrication MEP pipes rather than Revit system family? I can't help with that
