CONDUIT PROBLEMS
CONDUIT PROBLEMS
CONDUIT PROBLEMS
I am having trouble connecting two wall mounted junction boxes with conduit. It states "The routing solution failed because there is no default fitting type specified or the fitting cannot be found in the project. Ensure the fitting is loaded in the project and try again." how can i fix this problem and connect my two junction boxes with conduit.
Hello @Anonymous
Alwasys ensure that the routing references are all set.
You have to set up all the fittings requires for your conduit (see image)
All those fittings are located in the libraries
Here is the sample fittings from libraries (see image)
smbrennan
In addition to what Arjay said, check to make sure that the conduits are aligned. If they're a fraction off, Revit won't let you connect them.
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
Before doing anything make sure you're using the metric template.
If my answer solved your problem , Please Kudo  and Accept as solution.
