- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I am a Mechanical and Electrical Consultant Engineer who is relatively new to Revit and new to the forum.
I have received a Lift Family from a supplier and I want to simplify it as the level of detail within this Family is not required.
The family currently has families nested within families and families nested within those families all the way down to families even for the wall brackets. I want to remove the holes in these wall brackets as they are not necessary for my level of modelling.
I want to combine some of these families into one without nesting them to reduce the file size as the Lift Family is currently over 30,000KB. I also want to do this so I can add Parameters to the family such as the Lift Car Travel Distance which will then determine the length of the Guide Rails and the Number of Wall Brackets needed.
Is it possible to combine these families together so the extrusions in each family is now in only one family?
I hope this makes sense.
I look forward to your replies.
