Close Hidden Windows Function Not Working
lorenzo.zambrano
lorenzo.zambrano
Hello everyone,
I am experiencing issues with close hidden windows function.
Simply most of the times I used it, it is not working. I also tried it in different files but I had the same behaviour.
At the moment I am using Revit 2018 on a Windows 10 64 bit OS.
Many thanks in advance for the help.
Best Regards,
Lorenzo
L.Maas
Do you have the active window maximized (so that no other windows are visible) when executing the command?
You aslo might have a look at the Revit journal file and check if something is mentioned there.
Louis
Please mention Revit version, especially when uploading Revit files.
lorenzo.zambrano
Hi Louis,
Thank you for your message. I just tried now a couple of times and it worked just once.
Also with a view maximised in the window the command is greyed out and I can't click it.
I checked the journal but I haven't found nothing probably because there is no error with the command, simply I can't start it.
