Change Panel Circuit Numbers to Letters
curtisridenour
Advisor Advisor
curtisridenour
Strange question. Is it possible to get the circuit breaker numbers to be letters instead of numbers?
ricaun
By default is not possible, why you need only letters?
On Revit 2021 you kinda could create a shared parameter and use the Circuit Naming Scheme, see video.
And use Dynamo/Plugin to populate this shared parameter on each circuit.
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
curtisridenour
My lighting designer wanted to use custom circuit naming for LCD panels and use letters to distinguish them from power circuits.
