Revit MEP Forum
Change how pipes display in wireframe
17 REPLIES 17
Message 1 of 18
Andrej.Licanin
2805 Views, 17 Replies
I want to change how the pipes display in wireframe so that they appear like they do when in  consistent colors mode,and the rest of 3d geometry is shown as wireframe. I have this screenshot that shows this fitting, it is shown as fill and i want the pipe (brown) to show filled like that also (not see through).
How would i go about achieving this?
17 REPLIES 17
Message 2 of 18
RobDraw
in reply to: Andrej.Licanin
How are the fittings getting the color applied?
Rob
Message 3 of 18
Andrej.Licanin
in reply to: RobDraw
But those fitting are shown in full color, so it should be possible .
Message 4 of 18
NimeshJ
Hello @Andrej.Licanin ,
Looks like you have applied some filter for pipes but (maybe) forgot to add pipe fitting to filter categories.
If you want pipe to look like solid, remove filter. I guess this will work.
Let me know if this works.
Tags (2)
Message 5 of 18
RobDraw
Have you checked the filters applied to the view?
Rob
Message 6 of 18
Andrej.Licanin
No filters are applied to the view .
Message 7 of 18
RobDraw
What visibility settings have you checked so far?
Can you share a portion of the model that displays as you show?
Rob
Message 8 of 18
Andrej.Licanin
ON V+V Ii checked pipes (model) but the pattern category cant be modified, under object-styles, there is nothing for patterns,  tried right-clicking on pipe and override graphis but there are only options for line and transparency.
There is no part of the model that displays like that, i need to use wireframe to see anything at all.Here is a bigger example
I don't understand why the fittings have filled color and the rest of the pipes do not
Message 9 of 18
NimeshJ
Dear @Andrej.Licanin ,
Do check filter too in Visibility/ Graphics Overrides.
Message 10 of 18
RobDraw
If you aren't going to share a model, you need to determine how the color is being applied to the fittings so that you can use the same method for the pipes. Screen shots of your model tell us nothing more than what has already been said. Screen shots of you V/G Override settings might help but the model would be much more useful.
Rob
Message 11 of 18
Andrej.Licanin
in reply to: NimeshJ
Dear NimeshJ . I did there are no filters applied. Can I achieve this by applying a filter?
Message 12 of 18
OK i figured it out, what I needed to do was to make a new filter -> apply it to a specific system -> change the pattern of that filter.
Message 13 of 18
NimeshJ
Ok good 🙂
Message 14 of 18
RobDraw
But you didn't figure out how the fittings are getting the color applied. Now when you remove the filter you will be back to where you started. You only put a bandaid on the issue. If that's ok with you, go with it. In my book you still have not solved the mystery of the fittings.
Rob
Message 15 of 18
Simply keep the view as consistent or shaded and VG set all other categories to 100% transparent.  Colors can be set under Object Styles > Material.
Message 16 of 18
mgalicki7M78A
in reply to: ToanDN
I now have an issue with FabricationCADMep.
I'm not seeing the piping in 2D wire Frame? I've tried the suggestion,
change VSOCCLUDEDLTYPE from 1 to 11.
It did not correct the view. Might you have any other suggestions?
Message 17 of 18
iainsavage
in reply to: mgalicki7M78A
Are you talking about Fabrication parts within Revit or are you talking about in the Fabrication CADmep software?
Message 18 of 18
mgalicki7M78A
in reply to: iainsavage
 Fabrication CADmep software, but I found the issue, In the layer dialog there were some locked that were not showing. But all is good now.
Thank you.
Forma Design Contest
