I am having to draw an architectural model which I have never done before. I want to make floors, walls, and ceilings different colors. how would I do this and also can I change the color of the objects that I have already placed in the model. thanks in advance.
Solved by m.voss.alvine. Go to Solution.
colors are controlled in the Object Styles
@Anonymous check out this short Screencast showing how you can tweak styles to show as colors.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
