Change color of linked objects in Revit
eh3YMC3
eh3YMC3
I want to customize my floor plan view by changing the colors of different objects. For instance I want to change the fill color of all walls to black. When I try to change this in the view template, nothing happens. Filter doesn't work either. Am I missing something?
iainsavage
If the link is set to By Host View it should adopt those settings but what is your view discipline? MEP disciplines won't show shading etc in architectural elements.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-D...
eh3YMC3
Hi, thank's for answering.
Yes, setting for all links is "by host view" and discipline for the view is "mechanical". Anything else that might cause this problem?
narsimhamurthy21
can you share that file for further examine it?
this is interesting I want to understand this and solve this issue.
eh3YMC3
Thank's! File is attached. You won't be able to see the linkes though, so I don't know if it makes any sense?
iainsavage
Mechanical is an MEP view discipline per my earlier question.
Change it to Coordination.
eh3YMC3
Oh, sorry I was misunderstanding your first message. Thank's, changing to coordination fixed the problem.
