Cfm & Size Tag
Cfm & Size Tag
Cfm & Size Tag
Hi. Maybe this is very easy, but i have a doubt. I would like to create a tag with the cfm and size for a duct system. How could i do it in Revit? By default, when i use "Tag by category", i just can see the duct size (I'll upload an image).
I hope you can help me with this. Thank you
debimmanager
Hi @Anonymous
Try this, 11332244
Thank you!!
Deivis E.
BIM Manager
robert.klempau
Hello @Anonymous,
you can create your own tag.
Tag your duct or load a tag from the library.
Then Edit your tag. select your tag and Click Edit family in the Ribbon.
In the Family editor select the label and select Edit Label.
In the dialog select the Flow parameter (1) and add it to the right side (2)
You can use the Break option to place the parameters in separate rows.
See the picture below:
In the attachment a 2017 family that you can use.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
