- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys,
I'm an architect with a very a limited MEP knowledge. I've been watching and reading online these couple of days regarding the AHU ceiling mounted units. I'm getting there but I though better to consult someone more knowledgeable.
I have a problem I must resolve, I have to solve the ventilation system for an apartment.
I have created the AHU unit from a generic model. It has 4 ports, with the necessary in/out duct connectors.
What I'm having trouble is that I'm not sure as to how the exhaust air and the incoming air will be handled, will it be directly to the wall or it should connect to the shaft so that then it can connect to a vertical in/out outlet for the entire residential unit. I would imagine it would have to be directly connected to the outside wall otherwise why use this system.
If that is the case, as I think it is, how do I connect the AHU unit to the wall with what connectors/ducts.
Please see attached the photos of the problem and my current progress.
Thank you!
