Cant connect 220V power plugs to the switchboard
Message 1 of 12
I cannot connect them, when I try I got this message: "The Voltage (220,00) for the Circuit is out of range for the Line to Ground Voltage for TÉRREO (The Line to Ground Voltage is specified in the assigned Distribution System)."
The connection only works if I connect a 127V power plug, but it won't do with a 220V one. Here's a video showing how I do it: https://drive.google.com/drive/folders/1uPPJ-OKqRIP2_D_nEkjDMQzxU8sVPFBi?usp=sharing
Replies (11)
Message 2 of 12
Do someone know how?
Message 3 of 12
RobDraw
I'm going to throw out a WAG.
The panel is 120V.
It's not really a guess. The warning tells you what the problem is.
Rob
Message 4 of 12
Actually the panel is suposed to be 127/220V, as you can see in the distribution. It should accept a 220V power plug
Message 5 of 12
RobDraw
Sorry, I didn't watch the video earlier but that doesn't matter. I'm having trouble following it probably because I don't do much electrical and need more time to get my head around it.
Can you share a model that exhibits the behavior? I can't really tell what families you are dealing with because I only speak English.
Rob
Message 6 of 12
Sure, no problem. Check the previous link, I just uploaded there the model I'm currently using
Message 7 of 12
RobDraw
Sorry, only 2020 here. Hopefully, one of the electrical guys will be along soon to help.
Rob
Message 8 of 12
Check it again, I uploaded a 2019 version
Message 9 of 12
Bump
Message 10 of 12
I tried to set the distribution settings today, but it won't work
Message 11 of 12
RobDraw
What won't work?
Are you saying that you cannot set them at all?
Rob
Message 12 of 12
