Can't make buildings with toilets.
kd0afk
Message 1 of 28
kd0afk
I downloaded the demo last night and when I went to create a plan, I found that I couldn't create any content. No electrical, no plumbing fixtures. Which is pretty great for right now. I have a job as an Amish Architect but in the future, I might want want to design structures that have modern conveniences.
Or is the demo supposed to be this useless?
Can someone help me out please?
Replies (27)
Message 2 of 28
scott_d_davis
the Trial Version  is fully functional...but you have to pay attention when you install.  There is a checkbox asking if you want to install content or not.  It looks like you did not install the content.  Launch the installer again, and it will recognize that the program is installed, but not the content.  Download and install the content from within the Revit installer.
Alternatively:  you may have installed the content, but are starting a project with a "blank" template, which would contain no objects.  Check for this folder: C:\ProgramData\Autodesk\RAC 2012\Libraries\US Imperial (or US Metric) and see if there is any content there.  If som then start a new project (File>New) and choose a Template at the opening screen.
Scott D Davis
Sr AEC Technical Specialist
Message 3 of 28
kd0afk
Ok ill try reinstalling it again.
Message 4 of 28
kd0afk
Where is this check box supposed to be?
Message 5 of 28
kd0afk
I went to reinstalling and it tells me that the material libraries are installed, and it won't let me proceed. It says that everything is good to go. But there us no content where it is supposed to be.
I have files in rac 2012, will it work right if I change the paths to that? Will those files work in revit mep?
Message 6 of 28
scott_d_davis
yes those files will work in MEP.  Check this folder for MEP content:
C:\Users\All Users\Autodesk\RME 2012\Libraries
You can use the RAC library, but you wont have all the MEP content.  You will have toilets, sinks, lights, receptacles, etc.
Scott D Davis
Message 7 of 28
scott_d_davis
sorry, not a checkbox in the new installer...its a button for Add Content on the installer screen.  From the Help menu:
Note: After Revit is installed, you can access the Add Content button by starting the Revit installation through the Add/Remove utility.
Scott D Davis
Message 8 of 28
kd0afk
It put everything in RME 2012. How do I fix this? Can I just c&p everything over?
Message 9 of 28
kd0afk
I want the mep content. I should have just stuck with plain old revit. How do I get the revit mep content. There was NO option to install content.
Edited by
Discussion_Admin
Message 10 of 28
kd0afk
I just tried to install the content from the add remove programs and still no love. When I try to load anything I have to hunt down the library, and when I finally find it it says there is no tag for the object do I want to add one. This is a big freekin headache.
How do I get the content files that are SUPPOSED to come with revit mep so that the have their tags and so they have all of the mep data.
This is pretty lame.
Message 11 of 28
kd0afk
I just tried to reinstall it and this is the error I get.
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\ILM\Common~1.cab. The file is corrupt
 Where can I get this file and how would I install it?
And I waited nearly 20 hours for this thing.
Message 12 of 28
kd0afk
It seems from a search that a lot of the cab1 files are corrupt on manual different products.
So is there a fix for this?
Message 13 of 28
kd0afk
So, everyone is just giving up? Thanks community.
Message 14 of 28
kd0afk
how do I un-kudo you? You didn't help.Smiley Sad
Message 15 of 28
CoreyDaun
Try submitting your question with Autodesk Feedback/Support through this link. I used it for several of my posts like the ones that didn't receive any answers or replies, and they were able to help.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 16 of 28
kd0afk
Did that, any idea how long it takes for them to get back with people?
Message 17 of 28
kd0afk
Just got done downloading the thing again and this is what I got when I unzipped just the content folder the only folder I needed.
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\ILB\Autode~1.cab. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\ILL\Common~1.cab. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\CM\Materi~1.cab. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\ILB\BaseImageLibrary.msi. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\ILL\LowImageLibrary.msi. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\ILM\MediumImageLibrary.msi. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\ADSKMaterials\2012\CM\ProteinMaterials.msi. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\AM-en-US-i-Lib.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\AM-en-US-m-Lib.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\ASM-en-US-i-LibTmpltFamtem.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\ASM-en-US-m-Lib.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\ASM-en-US-m-TmpltFamtem.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\ASM-en-US-x-Ies.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\ASM-en-XX-i-Famtem.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\ASM-en-XX-m-Famtem.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\M-en-GB-m-Lookup.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\M-en-XX-m-Famtem.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\M-en-XX-x-Lookup.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\master.rac.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\master.rme.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\master.rst.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\RME-en-GB-m.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\RME-en-US-i.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\RME-en-US-m.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\RME-en-XX-x-Help.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\SM-en-US-i-Lib.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\en\SM-en-US-m-Lib.xml. The file is corrupt
!   C:\Users\Shawn\Desktop\Autodesk_Revit_MEP_2012_English_Win_32-64bit.exe: CRC failed in Content\Revit\master.xsd. The file is corrupt
This is nonsense. How can I get this thing through just a link without the akamai download manager? I have watched full seasons of television shows on hulu quicker than this thing took. And there weren't episodes left out either.
 There were 9393 errors total.
Message 18 of 28
CoreyDaun
It seems that if the problem is relatively simple or straightforward, they could get back to you the same day. Otherwise, they can take a few days if it's a major issue or maybe if they're backed up. I can't say for sure, though.
Message 19 of 28
kd0afk
I got the new uncorupted file from autodesk, did a clean uninstall but it still won't install the content. Somewhere there is a file that is messing with my computers memory. It thinks the content is still there.
I sent a message to autodesk. Hopefully we'll get this worked out.
Message 20 of 28
kd0afk
I should have at least 5 days left on the demo to master it. That's enough time.
