Revit MEP Forum
Can not change the Nominal Diameter
2 REPLIES 2
pe_simon
143 Views, 2 Replies
Why I could not change the "Nominal Diameter" to 20mm even I have ticked the "instance" in parameter?
2 REPLIES 2
iainsavage
in reply to: pe_simon
Presumably its controlled by the connected pipe size?
Upload the family for more help.
craigjonnson
Have you linked the connector to the size? You can check by clicking the connector and on the properties of that connector the size has a little radio button. Once clicked, you can pick the size parameter value and load back into your project.
Forma Design Contest
