Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Can i have Plumbing pipe in nested families
2 REPLIES 2
fawzimasri7137
832 Views, 2 Replies
I have a repeated Bathroom core with slight variation in the location of the Plumbing fixtures within that core.
I created a nested family that allows me to move the plumbing fixtures around as needed to fit the architecture's placement of these fixtures.
My question is, can i have these connected with to each other and to a main external connector visible to the hosting revit project?  This way even if i move a fixture, it stays connected to its necessary pipes, and i do not have to redo the connectivity of each fixture all over again?
2 REPLIES 2
L.Maas
in reply to: fawzimasri7137
Piping are system families and can thus not be loaded inside a loadable family. Also connectors inside a family only work in the host family and will not be visible when inside a nested family.
Louis
Please mention Revit version, especially when uploading Revit files.
fawzimasri7137
in reply to: L.Maas
That's a shame... i was hoping that Revit has matured enough to do be able to see within a family.
i guess,. i have to use an Assembly for now and adjust Fixtures according to the room they're in.
Thanks a lot for your response...
Fawzi
